RE: Building the 7th Chadwick
Now that I have decided to put the retracts in I did a dry fit check. The retract instructions advise "cut away to clear tire" and "cut bottom out for gear clearance. Cutting away to clear the tire was easy. Now I need to build a bottom (from the firewall to the tail) I have not figured out how I am going to to that.
Ideas, hints and suggestions appreciated.
