RCU Forums - View Single Post - Ryobi 4stroke running
Old 12-28-2003 | 09:27 PM
mgnostic's Avatar
mgnostic
Default Ryobi 4stroke running
Some of you may have seen my mount for a Ryobi 4 Stroke in a previous post. Well, I finally got around to firing the thing up this afternoon. I used a standard 12 V. starter. It is a little slow getting started but once it gets spinning it will turn the engine over fast enough to start. The engine did start but I only had time to get in a few minutes run time before supper. I mostly ran it at idle with a couple of efforts to rev it meeting with mixed success. It would start to cut out after initally speeding up. It is likely that the carb need adjusting but as it is currently arranged the needles face the prop and are a little tough to get at with the engine running. I don't have any RPM measurements yet. My tach needs a new battery. Vibaration is an issue. Yeah, I know big ol' singles vibrate a lot but this was considerably more than my homelite conversion of bigger displacement. I haven't made any effort yet to have the flywheel turned down or balanced. I just borrowed the prop drive spacer from my long shaft Homie (it's too long) and threw on the first prop that would fit (an old MA 14x6). Even with no muffler it was reasonably quiet.
