New Switch
LEDZx, How are you accessing your battery leads to connect and disconnect them?
Every plane I own has the battery buried inside fuse, and the only way I can access my battery is to remove the wing. Every plane I have ever seen has the same setup.
If you are leaving your wires outside the fuse so you can access them quickly that is not a smart idea as there are to many elements outside the plane that could disconnect the leads.
Randy
