RTN,
The ideal way to do this is: in the auxch screen, assign cahnnel 6 to NULL.
now go to prog mixes, pick a mix you arent using.
master = OFFSET
slave = FLAP
switch - (desired switch and position)
RATE = 100% (for starters, adjust as needed to get actual desired down flaperons)
TRIM (not available)
LINK ON
This will "offset" or move your flaps a preset portion of their total travel.
Sincerely,
AnnMarie Cross
President
Crosswinds Equine Rescue, Inc
http://www.crosswindseqresq.org/
