RCU Forums - View Single Post - nwe switch
Thread: nwe switch
Old 05-21-2002 | 01:59 AM
atvracer's Avatar
atvracer
My Feedback: (17)
Default nwe switch
so far I figure it's going cost me about $150+ I had a closer look at the switch I took the plastic cover off and the ground wire came lose it had a cold solder joint and it is a brand name switch. the joint must been good enough to pass test inspection but with a little vibes the joint failed as in my case a half a tank
