RE: GWS Zero
The 2/3 is is saying that the battery is 2/3rds the size of a regular AA battery. If you only have a 100 mah then that is a major problem. It will now provide the power you need for this motor. You will burn that pack up real quick. I am thinking that it must be a 1000 mah pack or you would never get it off the ground.
