RCU Forums - View Single Post - Glueing Question
Old 12-30-2003 | 12:45 AM
DBCherry
Default RE: Glueing Question
Thin CA on wood joints is fine, and stronger than the wood itself. One caveat; the joint must be a good fit. Thin CA will NOT fill gaps, so if you have gaps you're better off using medium.
A little test. Take a couple pieces of the balsa sheet that the wing ribs came out of and glue together with Thin CA. Once they've set try to break them apart.
Dennis-
