RCU Forums - View Single Post - Programing 9C for two throttle servos
Old 12-31-2003 | 10:39 AM
evan-RCU's Avatar
evan-RCU
Default Programing 9C for two throttle servos
Anyone know how to program a Futaba 9C so that I can have two seperate throttle servos plugged into two seperate slots on the receiver and get the throttle cut and trim to work the same on both.
Also do you know a way to then mix rudder to both of them and not over run the throttle servo at full throttle or kill an engine at idle. In other words at full throttle if I give it right rudder I don't want to go any more throttle on the left engine because it's already at full throttle an if I'm at idle and I give it right rudder I want the left engine to increase but not kill the right engine.
I hate to say it but I also need all this with out using too many mixing function as it's all for a Delta with two servos per elevon and I've already used a lot of the mixes.....
Thanks.
