RE: How do you clean an airplane?
Yub, yub, cmdr!
I'm in Medway! Right down 495 from you.
Nilo,
Did you click on the yellow search box. I entered cleaning your airplane and found a ton of great info from imixing your own exotic cleaning solutions to using windex or 409. One of the most common that I think I will try is a 50/50 solution of denatured alcohol and water with a small amount of dishwashing detergent.
Good luck.
