 How do you clean an airplane? >
Old 12-31-2003 | 12:55 PM
Default How do you clean an airplane?
What should I use to clean my plane (Hangar 9 Alpha Trainer) after a day of flying?
Old 12-31-2003 | 01:05 PM
Yub, yub, cmdr!'s Avatar
Default RE: How do you clean an airplane?
Windex??? My Tiger II manual suggests Windex.
Old 12-31-2003 | 01:23 PM
Thank you. I found a ton of good ideas using the search function. Now that I know about it, I will use it first.
Thanks again.
Old 12-31-2003 | 01:27 PM
Hey Chris, Where in MA? Near Worcester?
Old 12-31-2003 | 01:52 PM
nilo's Avatar
Does windex removes all the oil mess in the fus from the muffler?
I tried two types of cleaners but none removes the oil easy.
Then I used alcohol for general use from drugstores, but I'm looking for something else.
The search tool in "magazine" doesn't have anything about this as far as I searched.
Nilo
Old 12-31-2003 | 02:06 PM
Yub, yub, cmdr!
I'm in Medway! Right down 495 from you.
Nilo,
Did you click on the yellow search box. I entered cleaning your airplane and found a ton of great info from imixing your own exotic cleaning solutions to using windex or 409. One of the most common that I think I will try is a 50/50 solution of denatured alcohol and water with a small amount of dishwashing detergent.
Good luck.
Old 12-31-2003 | 02:07 PM
Dago Red's Avatar
Baby wjips, seriously, I use thouse, work great.
Old 12-31-2003 | 02:15 PM
Here's a recent discussion on the same subject:
http://www.rcuniverse.com/forum/m_13...tm.htm#1379085
Old 12-31-2003 | 02:25 PM
nilo's Avatar
Thanks, that was actually posted by me before, but nobody was answering so I lost it. Seems the feedbacks came up and that's all I need.
Nilo
Old 12-31-2003 | 02:53 PM
Oh cool!!! Chris, are you going to fly at CMRCM? Or is there a closer field?
Old 12-31-2003 | 02:59 PM
The solution that works best for me on glow fuel that is a castor/synth mix is windshield wash fluid mixed with bit of alcohol. I use the blue paper shop towels, they hold up better than kitchen towel. If the plan's not too messy then the baby wipes work well....
Old 12-31-2003 | 03:24 PM
combatpigg's Avatar
SIMPLE GREEN is a non toxic biodegradable product that works. Straight METHANOL works,and is relatively safe. Any detergent degreaser sold at auto parts stores works, stay away from solvent types that can loosen decals and covering
Old 12-31-2003 | 06:10 PM
My Feedback: (9)
yub yub and chris, i am from haverhill ma......
Old 12-31-2003 | 09:33 PM
ifixairplanes, do you fly at CMRCM? I will fly there.
Old 01-01-2004 | 09:11 AM
yub, yub, cmdr!
What and where is CMRCM!
Chris.
Old 01-01-2004 | 09:33 PM
It's a Club in Westboro.
Go to www.cmrcm.org
Old 01-02-2004 | 01:40 PM
I thought everyone used "Prop Wash".
Old 01-02-2004 | 06:44 PM
ORIGINAL: Askalon
That's what you use to clean the mud, grass and insects off your props.....
