RCU Forums - View Single Post - Engine Care ??
Old 01-02-2004 | 06:29 PM
bdtsr
Default RE: Engine Care ??
Humidity will play a big part here as the alcohol will attract moisture. Run the engine out of fuel then use a quality after run oil or other substitute. I use Marine Engine Fogging Oil. It's designed for long term protection of the iron and steel used in engines from rusting and helps to prevent moisture intrusion. It will also burn right out when you start the engine again. You'll here of many other remedies as well, this is just what I use.
