RE: Dazzler mods
wheels, if you use balsa triangle stock glued on to the surface instead of sanding down the bevels at the aileron, elevator and rudder hinge joints you will add length and its a lot easier.
The kit builds a lot lighter than the ARF. I went as light as I could, OS 32 SX, Hitec 85MG servos, smaller fuel tank and 300 mah Nimh battery. Was able to hover and pull out. Good vertical. Very light flying plane.
Ed M.
