RCU Forums - View Single Post - Do you consider checkbook modellers to be second class citizens?
Old 01-04-2004 | 08:54 PM
  #90
David Cutler's Avatar
David Cutler
Default RE: Do you consider checkbook modellers to be second class citizens?
No where do I see that you have to build your own models to be considered a true AMA member.
When I started in this hobby, just after the Neolithic era, some people considered it bad to build a plane using plans, let alone buying a kit (which, at that time, didn't even use die-cutting and you had to cut out the ribs and formers yourself) or an ARF (which didn't exist then).
They were also wrong to have that opinion!
You do what you want to. It's a great hobby where you can express yourself, not a means of keeping up with other people's phobias.
-David C.
