RE: Warped Ailerons
You can try heating the covering if you used an iron on and removing the warp. If you can't do that, then try to center each aileron so that there is as much warp going up as there is going down. Hope that makes sense. Your Tiger will fly, but get it as close as you can and have an experienced pilot look it over and test fly it for you.
