You don't want to skimp on hardware for a 1/3 SA plane. If you don't have nice, slop free, reliable linkages and servos, flutter will kill the plane in short order. As far as linkages go, basically if you use anything that is in line with the original RocketCity stuff you'll be good to go. Spend as much as you can afford on any servos you need.
