RCU Forums - View Single Post - Lanier Slasher and Ripper?
Old 01-07-2004 | 12:45 AM
rcfury's Avatar
rcfury
Default RE: Lanier Slasher and <span class=
ORIGINAL: Montague
Seriously, nice looking plane. I'm curious about a couple of things. It's hard to tell from the picture, is the wing tapered much? What is the wing chord at the root at tip? How much does it weigh, and what are you using for an engine?
Thanks, yeah i really like the design. The wing tips give it that mean look, well a little. &lt;lol&gt;
Well im using a OS CV-A .15 for a motor spinning a MAS 7x4 prop
The taper on the wing is not that much but you can defantly see it. The chord at the root is 7 1/2 inches and at the tip is at 5 3/16th inches. Not including the 1 1/2 inch alerions.
During building i didn't include the leading edge plastic protective sleeves, and used mini servos which brings it just under 2.5 pounds.
