ORIGINAL: DavidR
<SNIP>
JR Do you want to install a thingamabob from Joes electronics shack on the radio of your model? What happens if that thingamabob causes RF interference and causes your model to go into PCM lock out and crash? Hmmmmm..... AMA mandated that device>> I think I will sue the AMA!
I got to think about that line of logic. The AMA mandates which turbines you may select from. By your logic, should we ban them all?
The AMA banned turbines years ago, then created a waiver. Because that could be the basis of a suit, should we cancel all waivers?
The AMA determined several years ago that a 5# plane at 60 mph constitutes lethal force (or something close, someone else can give the numbers exactly). Should we ban all planes above those ranges?
JR
