RE: Wanted: Float plans for Lazy Bee
Conventional floats work fine on a LzB. Probably better than the factory teardrop floats. If you have the .15-size, use something approximating 21" for the float length. I had the Big LzB and used 32" floats with complete success. Mount the float to the existing axle. add another axle to the bottom of the fuselage for the rea mount. Slide the wire fore-and-aft to set the incidence before you lock it to the airplane. I never used a water rudder.
