RE: cap 232 Hover?
Hey Guys heres my set up!!!
I have a Hitec Micro 555 reciever a Hs-81 for throttle servo Hs-425bb elevator servo a Hs-475hd rudder servo and a Hs-525bb hi speed aileron servo, and a 600MaH batterpack for gear, with the Webra 50 with slimline muffler for power. I also made the hole in the formers that hold the sheeting on bigger and was considering buying carbon fiber landing gear, i didn't sheet the cockpit either I'm just going to cover over it. This plane should come in around 5lbs!!!!!!! Hope this helps!!
Josh
