RE: GP Pitts throttle hookup
I would cut the throttle arm shorter so it clears the choke arm. Then, drill a new hole and bolt a ball link to the arm. Once you do that, you can loosen the arm and rotate it so that it just clears the fuel inlet. Once you do this, the arm will full open the throttle, yet clean the choke arm when you pull the throttle back without it resulting in the arm point straight at the firewall.
John
