RCU Forums - View Single Post - Nose wheel question
Old 01-11-2004 | 06:14 PM
rcu guest-delete
Default RE: Nose wheel question
Big Pete, the nose wheel linkage should have no stiffness at all, you should be able to steer the nose wheel from the servo push rod
( with hte servo disconnected from it of course ) with almost no friction. On a plane up to .60 size a standard servo will work perfectly on that function. Sounds like you have a problem there, check your install against your airplane instruction manual. If you have ANY questions, no matter how simple it may sound, just ask here or e-mail me at <<[email protected]>>
