RE: Help with wing setup for Ultra Stick 60
Got a heat gun? Heat up the aileron, top and bottom while twisting it in a slight reverse bend from what it is now. Hold it till the ultracote cools a little. Check the results. Idealy, the correct amount of heat would be just enuff to release the glue and let everything shift just a little.
Ed M.
