RCU Forums - View Single Post - MK Skystar - build started
Old 01-12-2004 | 07:55 PM
Boss248's Avatar
Boss248
Default RE: MK Skystar - build started
Jon...That is the first slide barrel carb I have seen on a plane motor...used them in r/c car racong mostly.
The header is easy to bend ...heating it will sure help...I bend Macs headers all the time...just a little heat is needed. I wear welders gloves and just heat the section and give it a bend.
Do you think you are putting enough horse power on the plane
