RE: Seagull Spacewalker II .40 ARF Control Throws
Will,
Thank you again for the very helpfull information. If you don't mind, I have a few other questions to ask of you.
1. Would you have any pictures of your battery and receiver installation?
2. What angle did you mount you 4-stroke .72 engine. (Was the head mounted to the side of the fuse or at 45° where the original engine mount is positioned)
3. Did you have to adjust the engine thrust angle?
4. Did you hook up you Ailerons using a "Y" Harness or did you hook them up to use them as Flaperons.
I really appreciate your help and hope you don't mind all the questions.
Thank you again,
John
