RE: ARF for the ENYA ? PLEASE Enya flyers HELP!
Dennis,
Take a look at the Yellow Aircraft .30 sized models. I have my .53 4-stroke in an older EZ .30 Sukhoi and the match is as close to perfect as I could have ever wanted. From what I've seen in this forum, the .53 would be a natural home in the YA models as well.
As far as mounts go, you can always grind away the rear web as it doesn't do a whole lot once the mount is bolted to the firewall and the engine is installed. Sig still uses separate beam mounts in their kits and they work fine. If the beam itself gets in the way, you may need to pass the pushrod off to the side, go forward past the arm, make a U turn with the pushrod/cable, and attach it to the throttle arm from the front. This is pretty much standard practice with 4-strokes due to how close the throttle arm is to the firewall.
John
