RCU Forums - View Single Post - New Defiant under construction
Old 01-13-2004 | 04:51 PM
  #32
tschmidt
Default RE: Defiant #2
ggrigsby, The wing sets on the thrust line and the stab is .5" above. Also, there is no dihedral in the wings (tube is on center of airfoil) I believe this is why the plane rolls and snaps so well. Also, I have not had to use any mixing flying the advanced pattern.
Even though the wing sets higher than most patternships, there is still a lot of fuselage area above the wing which helps visually in the air.
Thanks, Todd
