RCU Forums - View Single Post - H9 j3 CUB-pOSSIBLE TO TAKE OFF?
Old 06-21-2002 | 08:22 PM
quint-rcu's Avatar
quint-rcu
My Feedback: (24)
Default H9 j3 CUB-pOSSIBLE TO TAKE OFF?
Keep in mind that Cubs are some of the hardest planes to take off without ground looping or premature lift-off. They look like gentle trainers, but around here it's been fun at times watching 'hot' pilots fighting a new cub all over the runway. I have an H9 with a .65 Saito and a 13 x 6 prop that will take off a sweet as a lamb if you do it right, but will bite you the first chance it gets if you goof...
  • The J-3 has a very narrow stance and critical gear placement relative to CG.
  • You must let the tail come w-a-y up since the shape of the fuselage bottom will fool you into thinking it's nose low when the wing is still at a positive angle of attack.
  • You need toe-in on the landing gear to avoid ground loops.
  • You should use a large diameter, low pitch prop and bring power on gradually. (in fact they will usually break ground before you're all the way up on the throttle)
  • NO ailerons (well at least the least you can get away with) on take off. Cubs fly well on just rudder.
  • If you have a computer radio, mix 20 - 25% rudder with your ailerons just in case you have to level the wings on take off and use them. - It sure improves the turns too.
  • Keep it at a fairly flat climb angle and don't make hard turn inputs until you have flying speed after take-off.
  • Make sure both wheels are free and one is not binding or harder to spin.
The list can go on more, but that pretty well vents my spleen -
quint
