RCU Forums - View Single Post - GP Chriten Eagle II + Fuji 50SA + Spring Starter???
Old 01-14-2004 | 01:18 PM
hilleyja
Default GP Chriten Eagle II + Fuji 50SA + Spring Starter???
Has anyone put together this combination? Will the spring starter fit? If so, is there enough depth inside the engine mount block for the spring starter and will the extra-large hole needed weaken the strength of the block for mounting the engine? Any suggestions?
One more thought: I read some of the posts about mouting the DA-50 to the CE. They mentioned something about exstending the mounting bolts from the standoffs, through the box, and into the firewall. Is this a recommended alternative to the instructions that say to mount the engine to the box wall?
