RCU Forums - View Single Post - H9 Cap 232 (smaller one, not the big one) snapping
Old 05-24-2002 | 11:07 AM
Mike Wiz
Default H9 Cap 232 (smaller one, not the big one) snapping
Almost all of today's scale aerobatic models are elevator sensitive because they are designed that way. Why, because 3D flight requires a very effective rudder and elevator. Usually, people don't get into too much trouble with an over sensitive rudder, but the elevator is another story.
When I'm flying a new aerobatic plane I set up the elevator at the lowest recommended elevator throw and I set up another rate that's 1/2-3/4 of that throw and I always dial in some expo. I also use the front of the CG range. This will greatly desensitize the elevator which is very important to me in the beginning. As I become more familiar with the plane I begin to move back the CG and then dial in more throw if I feel it's necessary. If you want 3D ability, I recommend you set up dual or triple rates so you can have wild throws while stalled and sane throws for everything else.
BTW, I've owned a couple Caps, an Edge 540, a Staudacher and a One Design. All of these planes had sensitive elevators.....nothing like the typical sport planes I was use to.
Wiz
