RE: Aerofly pro problem
You mentioned adding RAM. Did you leave in your other RAM chip? If so, try removing it. Also try reseating your new RAM module if that doesn't work. If all that doesn't work remove your new RAM and try your old RAM just to verify that it is the problem.
