RCU Forums - View Single Post - Seagull Spacewalker II .40 ARF Control Throws
Old 01-15-2004 | 10:50 AM
2mistakeshigh
Default RE: Seagull Spacewalker II .40 ARF Control Throws
Will,
Have one additional question for you. Did you change or do anything special with the Fuel Tank installation? I tried to assemble the fuel tank per the manual but I think I may have not set it up correctly due to the plastic fuel tubes supplied with the kit and having to heat them up in order to bend them.
I was just wondering if you would suggest changing the fuel tank to another type and how you secured it in the nose. I was thinking of installing it using foam on the FWD side of the fuel tank between the fuel tank and the firewall. Then also adding foam between the tank and the top of the nose.
I have not figured out how to secure it in there to keep it from moving around. The manual suggest that you epoxy a support brace just above the fuel tank to keep it secure but that seems like a permanent installation and I would not be able to remove it if needed.
Again, thank you for your help and hope to hear from you soon.
John
