RCU Forums - View Single Post - 9C timer - unusual glitch when counting DOWN from 0.
Old 05-25-2002 | 01:07 AM
MyStar-RCU
Default 9C timer - unusual glitch when counting DOWN from 0.
AnnMarie and all,
The timer function does not work correctly when the timer is set to down and set to 0:00 in the timer menu. Instead of counting down from "- 0:00.0" on the home screen like it should, the timer starts counting down from ":9:13.0"... Note: The colon to the left of the 9 is not a typo error on my part; that's the way it appears on the home screen.
This applies to both S1 and S2 timers and does this regardless of what you set to trigger the timer, IE: stick throttle, power on, or toggle switch. Note: When the timer function is set to up and set to 0:00 in the timer menu, the timer counts up from 0:00.0 like it should...
**MODERATOR COMMENTS -- ALL COMMENTS ABOVE THIS LINE ARE OBJECTIVE AND CLEAR. THANK YOU!**
I'm just doing my part as a responsible modeler by reporting a problem to ******* the proper person. **************EDITED BY MODERATOR. VERBALLY ABUSIVE COMMENTS WILL NOT BE TOLERATED.**********
Don
