RE: Prop nut spinners
If you use one, CHECK IT OFTEN! They are usually machined from aluminum and if you over tighten, and damage the threads, they can come off as in the case of using an electric starter. This happened to me. I was lucky and caught it before the engine started. Just a word to the wise.
