RE: Cen Mt2...
A carb restrictor is in the venturi of the carb. It's a conicle piece of metal or plastic that restricts the amount of incoming air to help stabilize the atomization of the fuel/air mixture. Taking it out increases air flow, so you have to increase the jetting, but it may run a little more spuratic. You can pull it out by hand or with pliers.
