RCU Forums - View Single Post - Balsa USA Citabria Pro
Old 01-17-2004 | 01:28 PM
Patriot's Avatar
Patriot
Default RE: Balsa USA <span class=
After shogun talked about mounting his servos in the tail, I can't help but think I should do the same since I am using a 34 oz motor in the front. I am also mounting the tank over the CG. Maybe by mounting the servos in the tail, it will lower the weight a little by getting rid of the balsa supports and the control rods?
Patriot
Kinda bums me out, since I already have the servos and control rods mounted. []
