RCU Forums - View Single Post - Electrified Partner
Old 01-17-2004 | 04:16 PM
  #36
spbyrum
Default RE: Electrified <span class=
Guys
How exactly are you attaching the prop to the motor. The shaft on Tony's motor sure looks like a YS crank shaft and thrust washer. Is that a commercial adapter, or is the end of a crank cut and drilled for the motor's shaft?
