Well sort of. I really like this plane and after spending 4 months really putting in the hours, i decided to improve things! The fuslage is now very much like the ZN line synergy 90 3D. It is deeper than the original flip by around 30% also it is curved on the bottom like the synergy. Also it now has a removable belly pan again AKA synergy! the pipe now is hidden under the wing. I have also lightened the airframe quite a bit.
Overall all improvements have helped. It now holds KE very well without coupling, also its even better at 3D because its lighter.
Engine : OS 50SX with hatori 544 tuned pipe.
Servos : JR 591 all round with carbon 3mm torque rods and balls links
Radio : JR PCM 10X
Well go on, get that knife out and get modifying. You may just be pleased with the results, i have been.
Andy
www.3drc.info
