RE: Newbie throttle problems. Need info
The easiest way I figured out to hook everything up on my SS is to plug the items into the receiver so that the throttle is on the left stick and the rudder and elevator is on the right....trial and error basically. There may be a better method, but that is what worked for me.
You may have to reverse the directions of some of the channels for the servos and/or speed controller to make everything move in the correct direction.
Also, something I had to figure out the hard way was that the motor will not start unless the left throttle stick is initially in the bottom (off) position for safety reasons.
I am no expert by any means though.....
