RCU Forums - View Single Post - Control layout...I changed mine
Old 01-18-2004 | 12:25 PM
Super-Hornet
Default RE: Control layout...I changed mine
Hi all
My Dragonfly stock is GWS Transmitter with Mode 1. If you followed the instruction manual, the Right Stick Up-Down (Mode 1) is throttle. Left Stick Left-Right is the tail movement.
I'm a Right handed person so I prefer chopper movement done by right hand and throttle on the left. So this is what i do:
Modified my TX with Right Stick retention metal to the Left Stick. Left Stick Up-Down spring to the Right Stick. I don't want to desoldered and soldered my TX's potential port wiring, so i swap around the RX channel. Now :
Channel 1 goes to Servo 1 (The one that make your Chopper Head goes up/down).
Channel 2 goes to Servor 2 (The one that make your Chopper bank left/right).
Channel 3 goes to Main Motor (or mixer for Main Motor control)
Channel 4 goes to Tail Motor (or to PG-03 Gyro input)
Super-Hornet
