RCU Forums - View Single Post - Hangar 9 Edge 540 query
Old 01-18-2004 | 02:03 PM
DGrant's Avatar
DGrant
Default RE: Hangar 9 Edge 540 query in response to Ronbo
And again......here's the final product. To wire it ..I used a tube installed in the fusalage to capture the wiring....or you can make one out of paper/card stock...or Don's hobby has them(For $10 you can get a lifetime supply of the stuff)... or if you have any other way to secure the servo wires in the fuse I'm sure you can figure it out.
I used a servo-reversing Y-harness from Horizon hobby... come to find out later..I could have just programmed it in my radio(I pretty much knew it then too)...anyways..... A 9CAP is what I use... and it will work a few different ways with that transmitter, depending on the reciever, will tell you which way you might want to go with it. I've done 3 of these so far, and each one a bit different in the way it was totally done.. but these pics are prototype of my first one(the one I own), and I may upgrade my programming and ditch the Y-harness, as I do see slight advantages to programming it in.............so........that does it for DGrant's H9 elev servo install......stay tuned for more episodes.... LOL... I do hope this does help though.... I'm going to the shop now.... I have urge to build for some reason....
