ORIGINAL: dick Hanson
yeh -added drag changed the picture.
Also -the wheel pants add area - so no matter how streamlined - you have more surface area.
which equals more drag.
But as mentioned - you do look better with your pants on.
on a pylon racer - I would bet you couldn't tell any difference in lap time -pants on or off.
I still have a set of pylon pants and wheels - about 3/8" wide pants - over 1" in thick wheels.
About the added surface area, take a look at wing struts on just about any plane that uses them--Cub, Taylorcraft, Aronca, golden age racers etc. The struts are airfoil shaped. There certainly would be less surface area if they just used round struts but airfoiled struts are used because they offer less drag.
On a pylon racer you probably would win your bet about the difference in lap times not because wheel pants don't offer any advantage but because most pilots (including myself) aren't consistent enough to be able to tell a difference. But it is the little things that add up and the sum of all can make a difference.
