RCU Forums - View Single Post - Clipped wing tips on Flip, Hype Etc.
Old 01-19-2004 | 05:56 PM
Squabbler
Banned
Default RE: Clipped wing tips on Flip, Hype Etc.
Alright edible and errolw, lets see if I've got this right then. What your saying, is that when my elev. goes up at about 80% of stick travel, both my ailerons should go up 100% at that point (snap spoilerons)? And when my elev goes down, then, the same should happen in the opposite direction, right?
I'm a little apprehensive with this set-up because:
a) When I give full up elev (no spoilerons), plane snaps hard right.
b) I once tried proportional spoilers (mixed w/elev) and made plane less stable.
c) I once tried proportional flaps (mixed w/elev) and made plane less stable.
d) I once tried proportional spoilers and waterfalls were not as tight as w/out.
e) I once tried 10%, 30% and 100% spoilers and waterfalls were not as tight as w/out.
f) I once tried 10%, 30% and 100% spoilers and made plane less stable.
*I too am using the JR8103 and would like to assign the sprung (trainer) switch for snap spoiler/flap.
Can this be done?
*If the above cannot be assigned, would I have to use mix1 or mix2 as a point mix?
*I've only got about 45° of elev both ways because of my snapping issue.
Should I go more° to achieve harrier/elevators?
*Harriers and elevators are very unstable right now (no spoilerons/flapperons). Lots 'o wing rock
and other weird stuff, however, hovering & T/R is rock solid and I'd hate to loose stability in this area.
*Flat spins (no spoilerons/flapperons) are dynamite and fully controlable
Errolw, other than KE improvement, I can think of no other reason why you'd want to remove your tips, nor, why you'd want to bang your head against a wall for 7lbs. I think that'll take too long and there's gotta be a better way.
