RE: Evolution 46 problems
I had the same engine (until the crank snapped around flight 100 in mid air) and shortening the fuel line would be the fist place I would start. Also if you want more power drilling or removing the baffle inside the muffler will help the muffler is very restrictive. I believe your engine is having trouble sucking fuel through all that line you have hooked up to it while vertical.
