Originally posted by blowin dirt
Can I use an ignition system off a DA100 on my 3W150? I lost a wire on the stock ignition.
Yes, you can retro-fit the DA Ignition to a 3W engine. You must either install the DA pulse sensor and or rewire the 3W unit to accommodate the DA Ignition module. The timing will have to be checked as well. If you choose to do this I would suggest you contact DA for the wiring issues and an appropriate method of setting and checking the timing.
The DA ignition works on 6 volt's if there is a hotter spark realized it would only be as compared to the older 3W 4.8 units. Current 3W Ignitions also run 6 volts...
