RCU Forums - View Single Post - Seagull Spacewalker II .40 ARF Control Throws
Old 01-19-2004 | 10:39 PM
pdansalvish
My Feedback: (23)
Default RE: Seagull Spacewalker II .40 ARF Control Throws
I'm trying to figure out if I got a lemon. I built mine according to the lousy directions. I changed to dubro tank and mounted the receiver and battery between the fuel tank and the servos. I'm using an OS46 for power. My problem is the darn thing wants to fly sideways. On its first flight I had to add 1/4 inch of up to keep it level. Since then I added some wood under the trailing edge to push the wing down. I also add 1 washer under the lowest motor mount. My trim is now set at 2 clicks of up. My next step to fly it level is to lower the each aileron by 1/2 turn. But, I doubt this will solve the sideways problem. Anyone have a clue what I could try.
