RE: MK Skystar - build started
Thanks for the information, Jon. I have a couple of Bully 1.20s (which are basically WEbras) - the pumped, rear exhaust version. Yes, they would be overkill in the Skystar. I also have a new Hanno Special which I'll probably use. I think the plane can be built at about 7.5lbs (about 3.25Kg) using film covering; so the Hanno may be enough power. I've flown a 2 meter pattern ship (the Fascination) with the Bully 1.20. Good luck with your Skystar,
Will
