RE: Propeller questions!
eclipsegsxr - You can use a variety of propellers. What plane and what engine? If you really don't understand this yet, then you probably should steer clear of wood props. They do break easily and you won't be able to tell the difference between a wood prop and an APC in flight until you're a lot more advanced. As csdawggie said, the glass/nylon props are a lot more durable.
- Paul
