RCU Forums - View Single Post - Could I Put Monokote in my HUGE gaps to lower flutter or eliminate it??
Old 01-22-2004 | 10:14 AM
Stew99
Default RE: Could I Put Monokote in my HUGE gaps to lower flutter or eliminate it??
For CA hinges, you have to make sure the slots are deep enough and clear of any debris before you try to put the control surface on. I will usually dry fit the hinges several times before I glue them in place. If a hinge buckles when you try to press the surfaces together, don't even think about gluing it, take it apart and run an Xacto blade in the slot. Usually a little side to side motion will help wiggle the hinges into the slots. Once you have a tight fit between the surfaces, then hit it with thin CA.
