RCU Forums - View Single Post - Covering Question
Old 01-23-2004 | 07:36 AM
CafeenMan
Default RE: Covering Question
ORIGINAL: MinnFlyer
Ditto, I like to wrap the top covering around the LE so the seam is facing with the airflow.
Same here. Also, I have a way to cut a perfectly straight line that is parallel to the leading edge. If I'm covering the top, I turn the wing so it is standing on the leading edge with the bottom of the wing facing me. Put a long straightedge on the covering and lay the wing down. Cut the covering and it will give you about 3/8" that goes around the LE on to the bottom of the wing.
