RCU Forums - View Single Post - Can you answer this?
Old 01-23-2004 | 01:40 PM
FHHuber
Banned
Default RE: Can you answer this?
continuing to fly with flutter is about as bright as dousing the plane with gasoline and droppng a match on it.
Flutter (even that small movement high frequency tye you think is benign) can rip the gears out of your servos. It can snap the control horn off of the control surface. it can rip the hinges apart... it can shatter the entire aircraft if nothing else breaks first.
